Dave Bamford's 4.8 LSX Conversion
Discussion in 'LSX Tech' started by 8 SEC 109, Nov 15, 2011.
  1. 8 SEC 109 Member
    Message Count:
    312
    Offline
    We are mocking up this conversion with a $250 junkyard 4.8 truck motor, following the Hot Rod magazine 1200 hp recipe just for kicks. We will post up pictures, parts, numbers and prices of this conversion. We started by tearing the motor down, cleaning parts, opened both ring gaps to .028. Sent heads off to Total Engine Air Flow/ Trick flow heads.
    http://www.turbobuick.com/forums/lsx-tech/362352-4-8-5-3-ls-heads-cnc-ported-pics.html#post2903798
  2. Team Banana AKA Ronnie
    Message Count:
    930
    Offline
    I like this how long you think this build will take? I ask because we are doing something close to this and I would like to see the results.
  3. 8 SEC 109 Member
    Message Count:
    312
    Offline
    Contact Mike at Full Throttle all of your LSX conversion needs. Here are a few pic of products supplied by Full Throttle.
  4. 8 SEC 109 Member
    Message Count:
    312
    Offline
    More pics
  5. 8 SEC 109 Member
    Message Count:
    312
    Offline
    We are scheduled to have the turbos plumbed early January. I would guess it will hit the dyno in March.
  6. turboc87gn Darkside in Detroit
    Message Count:
    1,921
    Offline
  7. John Wilde Administrating and Player Hating
    Message Count:
    8,389
    Offline
    Dave,
    What tranny are you going to run?
  8. Squid4life Well-Known Member
    Message Count:
    4,904
    Offline
    This looks very interesting! Nice group of parts you got there.
  9. 8 SEC 109 Member
    Message Count:
    312
    Offline
    John
    We are running a bullet proof Rossler TH 210 with the Gear Vendors 6 speed overdrive. The initial dyno tests will be with the tsm Neil Chance converter, we will be upgrading to a PTC after the fire up.
  10. HOT ROD-GN Active Member
    Message Count:
    1,300
    Offline
    NICE!!
    Good luck on your Built.
    You Guys Built Bad A$$ Cars!!
  11. LC2ROD Member
    Message Count:
    277
    Offline
    Should be very interesting.
  12. 8 SEC 109 Member
    Message Count:
    312
    Offline
    Flywheel, adaptor and bolts
  13. streetknight DCVING
    Message Count:
    978
    Offline
  14. Blazer406 Mechanical Engineer
    Message Count:
    4,767
    Offline
    Me too.
  15. dennis1993 Member
    Message Count:
    41
    Offline
  16. 8 SEC 109 Member
    Message Count:
    312
    Offline
    Ted stopped by the shop today to degree the cam. Set the heads and intake on for a quick photo.
  17. John Wilde Administrating and Player Hating
    Message Count:
    8,389
    Offline
    Nice progress.
    ChanceG likes this.
  18. 8 SEC 109 Member
    Message Count:
    312
    Offline
    Measured up the pushrods, placed a call to Trend Performance picked them up the same day! This was at least a month long process in the past. We will be dropping it in this week to bolt in the new motor mounts.
  19. HOT ROD-GN Active Member
    Message Count:
    1,300
    Offline
  20. hemi8 Goin Sideways
    Message Count:
    486
    Offline
    Looks like a cool set-up, nice alternative to the 109.
    Mike
Share This Page
^ Top
