poor mans stage 2
Discussion in 'Stage II Tech' started by Goat, Mar 23, 2012.
  1. Goat I heart Boost and DRs...
    Message Count:
    898
    Offline
    Taking a production block and trying to build it for 600 crank HP. Going off this here: http://www.turbobuicks.com/articles/4point1ForCheap/
    Thought on bigger injectors, 6265, and not really sure on cam. Heads being worked good and some other things.
    Do ya think 600+ is possible?
  2. Squid4life Well-Known Member
    Message Count:
    4,959
    Offline
    The number is possible, but it won't be a stage 2, it'll just be a badass 4.1.
  3. Goat I heart Boost and DRs...
    Message Count:
    898
    Offline
    Ya didn't know where to put it, but you think its worth trying?
  4. Grumpy Thread killer
    Message Count:
    10,199
    Offline
    junk in junk out. The guy that did that went threw a LOT of motors an really never did squat at the track .
    Good, Fast, Cheap ........ pick any two.....
    If you want good and fast..... it's not going to be cheap....
    If you want good and cheap...... it's not going to be fast
    If you want it fast and cheap ...... it's definately not going to be good!
    L8TRH8R likes this.
  5. Pronto Question Authority
    Message Count:
    7,894
    Online
    According the that article the best he ran was 11.40. Totally doable with a stock block/unported heads/stock cam. I've only seen one guy around here with a 4.1 and it was alway broken.
  6. Grumpy Thread killer
    Message Count:
    10,199
    Offline
    hahahaha... BIG turbo an in a light Mazda !! "BUDGET doesn't belong in his article !! This was also broken way more than running !!! Oh as far as his prices ... Multiply them by 3 or 4 before he got it to stay together. Always had problems with it goin to the track.
  7. Pronto Question Authority
    Message Count:
    7,894
    Online
    The guy with the 4.1 that I saw was out of Fitchburg or there abouts. Met him a couple of times and he was always having issues. Last I heard of that engine it was getting "freshened" over winter. That was like 3 years ago.o_O
  8. Nick Micale Tech Advisor
    Message Count:
    5,942
    Offline
    A production 4.1 build make a great street/strip engine with LOTS of low end torque, and it can be reliable IF it is done properly.
    Before my alum block, I built a 4.1 with a virgin stock crank, custom forged pistons and steel caps with alum heads and ran low 10's for a few years. I sold the complete engine and it was used in a street car for additional years.
    I am currently building a production 4.1 stroker with all forged parts, solid roller cam and well ported heads for a high 9 sec. GN build. This will easily exceed 650 HP reliably.
    Of course this will NOT be cheap at $10K+.
    Last I checked, horsepower is NOT cheap in and make or model. :)
    SS/GN and charlief1 like this.
  9. jdpolzin Well-Known Member
    Message Count:
    6,774
    Offline
    I've built many different 4.1's so far and had no issues. They are a blast to drive and make a ton of power.
  10. Goat I heart Boost and DRs...
    Message Count:
    898
    Offline
    What would be a good reliable setup doing this to a regal I picked up today. So there is no way to get close to the claimed 500 crank HP with this guys build?
  11. cooled85T Empty Pockets
    Message Count:
    160
    Offline
    Mine made 585 wheel HP so it def do-able. Mine has been very reliable for the last 3 years and I have been hard on it.
  12. 6togo Member
    Message Count:
    642
    Offline
    Cooled85T have you been down the 1/4 with that setup any times?
  13. cooled85T Empty Pockets
    Message Count:
    160
    Offline
    10.24 at 134. Stock ecm and bad suspension holding me back.
  14. 6togo Member
    Message Count:
    642
    Offline
    How much boost you putting to it? Seen allot of street time or just track?
    Chris
  15. cooled85T Empty Pockets
    Message Count:
    160
    Offline
    About 21-22# to go that fast. Sees the street a lot. Spools up very fast.
  16. WIKEDV6 Well-Known Member
    Message Count:
    1,834
    Offline
    We have gone 10.009@132mph on drag radials with a production 4.1. The car would have gone into the 9's with ease but the motor was breaking up around 5200 rpm. It could have been a coil/module or even spark plug gap issues but we never got to make a clean pass after that because we broke the #2 stock main cap even though it had a Girdle on. This motor had over 100 quarter mile passes. 95% of them were in the 10's and the fastest being 10.009@ 132mph with 110 race gas along with an old school Fast system. It also made 604 RWHP at around 30 psi boost with a GT42/76 Turbo. The same motor in another car went 10.20's @132 on E85 with the MafPro setup. The car never hooked right though. I also believe the motor made 585 to rear wheels.
    The combo on this motor was; 291 cast production 4.1 block, RJC girdle, J&E pistons, BMS rods,( I think stock rods should have been ok) stock crank, Ported Iron heads with 1.77's and 1.50 valves, Flat tappet cam I want to say it's an odd grind like 222/216 or something but not sure. 120lbs injectors, 70mm TB and plenum, Ported intake Poston headers with HKS 46mm waste gate on the cross over pipe, 4" down pipe, TH400 trans with a brake and some crappy convertor, Weldon pump and so on.
    I think the #2 main cap broke while trying to spool up the 42/76 turbo off the foot brake when the trans brake switch failed. My buddy stood on the foot brake for a while. When I took the motor to the machine shop they said #2 two main broke, the crank was no good and the Girdle had warped. Since then I got a stock stroke (3.40) Steel crank another stock main cap ( I know I should have gone with billet cap) I also sent the Girdle back to Jason and RJC and had it resurfaced. This motor is going back in my TTA along with a 215-220 Full Throttle speed roller cam, Fully ported TTA heads and a GTQ 71 turbo and so on. I am hoping to make the same amount of power.
    All and all, if I didn't think it was reliable, I would have taken all of the guts and stuffed it in one of stage blocks I have sitting around. Who knows, I may crack the block on my first pass lol.
    HTH
    Prasad
  17. tom j Active Member
    Message Count:
    1,181
    Offline
    I believe I know that motor. The cam was a 218 and yes the converter was junk
  18. WIKEDV6 Well-Known Member
    Message Count:
    1,834
    Offline
    Yes indeed Tom, you do!!!!lol
    Prasad
  19. atomic six New Member
    Message Count:
    3
    Offline
    I believe I made that pass that went10.09 not bad for a shirt cam and converter must have been the driver and my pit crew
  20. WIKEDV6 Well-Known Member
    Message Count:
    1,834
    Offline
    It's wasn't the pit crew for sure, I think the driver had his diaper too tight and bailed on the gas pedal. Otherwise it would have been in the 9's for sure. You ran a 10.009 not 10.09. Remember the car started to break up around 5000 RPM too so you had to shift early as well.
    It's good to see you here Mikeee!!!!
    Prasad
Share This Page
^ Top
