UR FOOD Viper ACR
Discussion in 'Kill / Fish Stories' started by meanchicken, Apr 2, 2010.
  1. Turbo6Smackdown Active Member
    Message Count:
    3,286
    Offline
    I see now...
    At the end, my combos going to be pretty much where yours is.. (less the front mount) I just want to see where I would stand against a viper. By your description, your traction sucks. So if you leaned her out a little more, and got some serious tires (and then, if she still breaks em loose, which i doubt it, tighten up that converter) then I think you would have put a good whoopin on that snake for sure. I can't wait. (i have 28/10.5 et drags and a 2800 10" ptc non lock) I predict a good hook up on the streets. In which case a viper will get whooped after I get these heads ported.
  2. meanchicken gallo vicioso
    Message Count:
    4,992
    Offline
    It does a lot better with the DR's than it did with street radials...but traction is still an issue through 1st and early 2nd.
  3. Turbo6Smackdown Active Member
    Message Count:
    3,286
    Offline
    Sounds like you need some 10.5/28 mickey thompson et streets. Pretty much the stickiest option that's legal for the street. They're the biggest tire in width and height that'll fit in a gn wheel well, that have good traction. It's what I may end up getting, if I get harrassed too much with my ET drags.
  4. meanchicken gallo vicioso
    Message Count:
    4,992
    Offline
    Since I drive at least 50 miles a day on these DR's, I went with the ones that were supposed to be the best overall for both tread life and improved traction....I put htem on back in October and will be lucky if they last until summer at the rate I'm smoking them.:D
  5. Turbo6Smackdown Active Member
    Message Count:
    3,286
    Offline
    exactly. You're smoking them. Cuz they don't grip. :) get the ones that grip.
  6. supercrackerbox Will wrench for beer
    Message Count:
    395
    Offline
    I like this guy.
    Chicken, if you ever find yourself in my area with your car, get ahold of me. It's been a while since we've had any turbo Regals around to show the kids what's up. ;)
  7. Quik Six Active Member
    Message Count:
    824
    Offline
    I run 275/60/15 Nitto DR's and they do a good job for me. More tire patch on the ground and your TC should perform better.
  8. tlturbo Tag - WUTSA V8
    Message Count:
    507
    Offline
    I just upgraded from 275 60 15 Nittos to 295 55 15 M/T's - MAN what a difference. Went sideways with the Nittos but flat ass hook the M/T's. 15 x 10 wheels with rolled lip.
  9. TurboTGuy Gray Beard Member
    Message Count:
    1,602
    Offline
    I just got these.... Heh, heh, heh.....:D
    MT 275 60 15 Drag Radial Pro's
    It's supposed to be in the mid 80's this Saturday in Phoenix.
    Speedworld, here I come!:)
  10. meanchicken gallo vicioso
    Message Count:
    4,992
    Offline
    Since I wrote this...I went back to 275/60/15 street tires cuz I drive a lot and can't afford to buy new Nitto's every 6-8 months.
    At the track I still run MT DR's...but I have bought some 28" tall MT 9" slicks and some skinnies mounted to Weld Draglights for my next time to the track.....with my new stroker motor ready to breath deep.:D
    Deep n' easy 10's...coming right up....
  11. toomanymodz Active Member
    Message Count:
    757
    Offline
    Pretty impressive to hang with an ACR. I miss my 2008. That thing pulled really well. My GN isn't quite there yet, but getting close. The gremlin that is hurting my GN is that it stops pulling at 5400 RPM, like hitting a rev limiter. So far I haven't figured it out. Still ran an 11.18 in the quarter.
    I love reading about these 'kill's. Very good entertainment. :)
  12. TurboTGuy Gray Beard Member
    Message Count:
    1,602
    Offline
    Well Chicken,
    I went 10.76 @127 tonight on a horrible track.
    I was the first car to make a pass tonight and it was a 10.92 @ 124. Then things went kinda sideways. One pass was actually a 12.73 @124 and the car was all over the track...
    These new DR's don't like a big burn out, so that took a few drilling the tires scary passes to figure out. Once that was done we had to take out some boost and alcohol.
    I already had 7 passes out her when I ran the 10.76 and the track officials were giving me the stink eye so we called it a night.
    Still pretty damn fun though.:)
  13. meanchicken gallo vicioso
    Message Count:
    4,992
    Offline
    Geez! I can't believe they give you that many runs without a cage....when I ran my 11.14, the guy told me to slow it down or he'd boot me. Luckily it was the end of the day and I nly had time to get back to the staging lanes before they clsed them, so I went for it again, but lost traction...did an 11.22 on that pass even after loosing my grip at launch.
    Came back to the ticket booth for my slip and the guy just shook his head and handed it to me.
    Can't wait to get to the track with this new stroker engine Lou is building...it's coming along...gonna be an animal for sure!
  14. meanchicken gallo vicioso
    Message Count:
    4,992
    Offline
    You sure you're not creeping into valve float at 5400 rpm?
    Shouldn't be...but....who knows.
  15. toomanymodz Active Member
    Message Count:
    757
    Offline
  16. meanchicken gallo vicioso
    Message Count:
    4,992
    Offline
    Even tho 5400RPM on a Weber motor seems a bit low for float....that's where my money is.....it's either that or ignition issues unless you're running too lean on fuel (You have the injectors...but hows the chip calibration?).
    But you have Bison on the case....he know's his stuff big time.;)
    Funny how these Buick Turbo 6's behave a lot like GM big blocks....they don't need to rev high to make the power and TQ....and once you start getting into the upper 5K and low 6K RPM range....let the valve float begin unless you have the right springs.
    A nice set of Behive springs would do wonders for my ZZ502....but....all the fun money is going to the GN's stroker build right now.
  17. highboostgn Well-Known Member
    Message Count:
    1,394
    Online
    Is your build done yet?? I have nothing to read now here in afghan! hurry up! lol
  18. meanchicken gallo vicioso
    Message Count:
    4,992
    Offline
    HEy...stay safe in the sandbox OK....
    My block, cam and rotating assy are still at the machine shop waiting their turn but I'm in no rush.
    I should have pix of the carnage on the old engine soon. Lou pulled it apart today....snapped the crank, busted a main cap loose, two pistone wedged in their bores, and a couple slapped valves...OUCH!
    Having the trans and converter sent back to the builder for a recalibration for the new motor...loosen the stall....raise the shift points....
  19. TurboTGuy Gray Beard Member
    Message Count:
    1,602
    Offline
    MMMWUHAHAHAHAHAHAHA......;)
  20. highboostgn Well-Known Member
    Message Count:
    1,394
    Online
    Ha well 2 1/2 weeks and I'll have some stories to post one here:D
Share This Page
^ Top
