Won't Pass CA Emmissions
Discussion in 'Smog tech and emissions tech' started by VIRGIN87T, Nov 19, 2008.
  1. BoostedEvIL Novice
    Message Count:
    441
    Offline
    What was your fuel pressure at when you tested with the TT chip?
    I passed at 37-38 psi.
  2. Instro84 USAF retired
    Message Count:
    1,075
    Offline
    I got to autopros 2 in rosamond on sierra. i may try and keep mine registered in missouri.
  3. VIRGIN87T Turbo Addiction
    Message Count:
    155
    Offline
    I did not change the FP. It was still set at 45 off-line.
  4. BoostedEvIL Novice
    Message Count:
    441
    Offline
    I think that might be your issue. Set it at about 37-38 with the TT chip. Then you should be golden.
  5. Gary Wells White turbo Buick trailer park trash
    Message Count:
    7,695
    Offline
    I would re-set the fuel pressure & have Lou Czarnota do a pre-smog.
  6. BoostedEvIL Novice
    Message Count:
    441
    Offline
    Lou is always a good call. Thats what I did.
  7. Gary Wells White turbo Buick trailer park trash
    Message Count:
    7,695
    Offline
    I would rather pay the extra money for a pre-smog than have my name and / or vehicle # on record at the DMV & Smog Stations as a failure. Just good plain insurance. Just my personal opinion though.
  8. Instro84 USAF retired
    Message Count:
    1,075
    Offline
    same here Gary. haven't had to get my buick smogged yet but its coming i know. the guy i go to with my other cars doesn't charge for the pre test if you bring back to him for the test.
  9. 1BADDAM Venomous Snake Handler
    Message Count:
    675
    Offline
    +1
  10. GTOGreg New Member
    Message Count:
    5
    Offline
    check timing and I've also heard that dyno tabs can help quite a bit.
  11. leophious Member
    Message Count:
    116
    Offline
  12. VIRGIN87T Turbo Addiction
    Message Count:
    155
    Offline
    Haha!! That's my next choice!!!
    Sounds good guys, thank you for all the help and suggestions. I will have to lower the FP and see if I can get it to Lou's shop for a test. My registration is already lapsed so I gotta go wait in line for a little temp registration now :( ... As Lou mentioned I am sure the timing chain has lost its tension in the timing chain as well. That has been something on my list for a long time, maybe now is my opportunity to change it....
  13. forcedfedv6 Banned
    Message Count:
    1,185
    Offline
    if you look at my post above #7, that is exactly what i suggested all along, lower the damn FP and you should be able to pass with flying colors, BTW, you cannot lower the fuel pressure with the TT chip, it has to be done at the FP regulator the old fashion way, LOL, you can also bump the timing just a tad by a degree or so that should also help bring the numbers down a bit while taking the test on the dyno..
    Let me know if you still need my help.. ;)
  14. Little6pack Active Member
    Message Count:
    6,388
    Offline
    MOVE! I know you don't want to hear that I am just being a Prik!
    We have nothing but visual here in NH. & only $5 for the inspection where I go. They can charge $1.99 to 45.00
Share This Page
^ Top
