Wrist pins choice
Discussion in 'Turbo V8 Conversions' started by KWIKR 1, Jan 23, 2011.
  1. KWIKR 1 Active Member
    Message Count:
    1,672
    Offline
    Looking to upgrade the wrist pins in a new set of JE Extreme Duty Invdome pistons . The pins that came with the set are JE's Standard Performance 51 series #927-2950-15-51s (Low Carbon Case Hardened ) . They have a wall thickness of .150" @ 139 grams . According to JE good for about 650hp in a NA application .
    Je suggest the 93 series pins (9310 Nickel Carbon Steel Alloy ) for a high HP boost application . I have two choices . One with a wall thickness of .150" @ 129 grams (#927-2950-15-93S). This is the one JE recommends . Or a set with a .170" wall thickness @ 148 grams (#927-2950-17-93S). Would I not be better off with the second set ? or would the pins be to heavy ?
  2. Louie L. Habitual Line Stepper
    Message Count:
    3,599
    Offline
    Im by no means a engine builder but i would use the the .170
    I run the same pistons upgrade. Just cant remember which of the two.
  3. KWIKR 1 Active Member
    Message Count:
    1,672
    Offline
    I think I'll contact the shop who'll be doing the balance job and fly it by them . Louie , did you go with the JE Pro Seal rings ? or did you step up a set of steel rings , Hellfires....or ?
  4. malibuick231 New Member
    Message Count:
    624
    Offline
    You should have bought my pistons I could have put them in the same box!!
  5. KWIKR 1 Active Member
    Message Count:
    1,672
    Offline
    :) in hindsight I most likely should of . Put I already had a set of brand new 5.7" forged H beams w/19 bolts on the shelf . Your rods/piston combo is based on a 6" rod . would of ended up with a extra set of rods . I got a real good deal on these JE's , that was the reason I bought them . so I'm still happy and ahead dollar wise . :) :)
  6. cdr.performance New Member
    Message Count:
    59
    Offline
    How much power are you trying to make?
    We use a lot of .190", .220" and larger sometimes
    Also depends on length.
  7. Louie L. Habitual Line Stepper
    Message Count:
    3,599
    Offline
    About 4 years ago all everyone would talk about was Hellfire. Thats what I used. So far so good.
  8. KWIKR 1 Active Member
    Message Count:
    1,672
    Offline
    as much as I can . :D :) at least in the 750-800 hp range .
  9. cdr.performance New Member
    Message Count:
    59
    Offline
    That is not too much an upgraded pin is need. If you looking for more a larger pin is worth the money. If you bend a pin you will have the SAW the piston in half to try and save the rod.... Getting good pins is important.
    Ring, Hellfires do work there are some better ring out these days. Again better cost more too.
  10. KWIKR 1 Active Member
    Message Count:
    1,672
    Offline
    I reading mix reviews on the Hellfires on a engine that will see street duty . saying they are a little hard on the cylinders for wear .
  11. cdr.performance New Member
    Message Count:
    59
    Offline
    Well anything that will hold a 1000hp will need to be tough.
  12. KWIKR 1 Active Member
    Message Count:
    1,672
    Offline
    ordered the JE 93 series .170 pins . we'll see what happens . :) Should be no problem on a 800-900rwhp from what I was told . :)
  13. cdr.performance New Member
    Message Count:
    59
    Offline
    0.170" is a little thin... It not just about handling the hp but being able to survive cylinder pressure spikes.
  14. KWIKR 1 Active Member
    Message Count:
    1,672
    Offline
    I could of went with a tapper wall .187" pin . Car is primarily a street car , I was told the .170" should be fine .
  15. KWIKR 1 Active Member
    Message Count:
    1,672
    Offline
    are you beter off using a tapper or straight wall pin ? I can get a .180" in both . or a .200" in straight .
  16. KWIKR 1 Active Member
    Message Count:
    1,672
    Offline
    contacted a few engine builders and a person at JE who knows his stuff... NOT friggin sales people . :mad: :) Upgrading the pins to a .200" wall 9310 Steel/Casidiam . :) you know you have a problem when you take the day off work to make sure you get the right wrist pins . lol . :D :)
  17. cdr.performance New Member
    Message Count:
    59
    Offline
    That sounds like a better choice.
  18. KWIKR 1 Active Member
    Message Count:
    1,672
    Offline
    I agree . :) the problem being is that JE markets these pistons as their "Extreme Duty" line of pistons specially designed for forced induction and nitrous applications . The problem being with a .150" wall wrist pin made from Low Carbon Case Hardened steel , they are far from being "Extreme Duty" . This may doop some people into thinking they are buying a turbo/nitrous piston set capable of supporting high HP numbers . The pistons are capable , the pins are not . always a good idea to do your homework and know exactly what you are getting vs what you need by talking and listening to the right people . :)
  19. cdr.performance New Member
    Message Count:
    59
    Offline
    Yes speaking with a shop that builds large forced induction motors can open ones eyes to lots of short comings with off the shelf parts. Plus all too often people are looking at nothing but the price........ Not a way to start off a build trying to break 1000 hp. You gotta pay to play. I am not speaking about top dollar billet unobtainium stuff, just enough to truly achieve your goal and not leave you with a pile of broken parts that fit into a five gallon bucket.
  20. malibuick231 New Member
    Message Count:
    624
    Offline
    Quit beating your self up over it!! You could have my pistons,rods,pins, and rings for $1000 plus shipping.
Share This Page
^ Top
