XFI Trans creep
karolko
was wondering how slow you guys have gotten your trans creep down to: looking to slow mine dow a little more than this:
Also it appears that it starts fast and then slows down a bit, usually it is suppose to increase in speed as time goes on.
i ave the pulse set to 20 and the acceleration rate set to 1, start and creep set to 9.8
Thanks for the help.
Adrian
I have mine that from the first stage light, it bumps to the second. Minimal time as possible to waste. Every second on the Brake is 100 degrees of heat added to the transmission.
JB, just to give me an idea, how long do you have your time set at. I know it will vary on how fast your creep is, but give me an idea.
PS: do you know the physical distance between the first and second beam? It should be universal.
Thanks in advance,
Adrian
i am wondering how many people use the timing function to control the amount of roll the car gets. if it works, that would be perfect, but if i stage slightly shallow to deep into the prestage bulb and the time the trans creep works is a little to short, i fear i might light up the stage bulbs and then what?
I'm curious what guys are doing? Leaving the time function to 25.5 seconds or setting a specific time?
Huh.
