M MiAde2d Member Joined May 31, 2004 May 22, 2016 #1 My question is.....my MC just went out. Am I better off going with an aftermarket set up or just find a stock unit.
B Boost231 What's An Intercooler Staff member Joined May 26, 2001 May 23, 2016 #2 Either will work just fine.. you can by a willwood for the looks but they are pricy Sent from my SM-N910T using Tapatalk
F Fast4Ward Well-Known Member Joined Mar 27, 2005 May 26, 2016 #3 Go to rockauto and put it together. MiAde2d said: My question is.....my MC just went out. Am I better off going with an aftermarket set up or just find a stock unit. Click to expand... Go to rockauto and put it together.
T toyin Member Joined Jul 9, 2010 May 29, 2016 #4 Does anyone have any good links to show the parts and a write of for doing the swap to hydroboost?
I Instro84 USAF retired Joined Jul 17, 2005 May 29, 2016 #5 got a master cylinder from my hydroboost sitting on the shelf if you want it, i bought one from Baer to match my brakes.
T toyin Member Joined Jul 9, 2010 May 29, 2016 #6 I have a hydro boost looking for info on lines. I think i'm just going to figure out the fittings and build a set of my own lines.
x96283 Active Member Joined Mar 18, 2013 May 30, 2016 #7 toyin said: Does anyone have any good links to show the parts and a write of for doing the swap to hydroboost? Click to expand... http://www.cedarcrestspeedlab.com/converting-to-hydroboost-brakes-turbo-regal/ I followed this guide to a tee and I'm still going strong two years later. good luck!
T toyin Member Joined Jul 9, 2010 May 30, 2016 #8 x96283 said: http://www.cedarcrestspeedlab.com/converting-to-hydroboost-brakes-turbo-regal/ I followed this guide to a tee and I'm still going strong two years later. good luck! Click to expand... Thanks for the link that answered my questions!
