T TurboSmart Member Joined Nov 6, 2013 Jan 6, 2017 #1 The only thing I know is that is a Extender chip. View media item 245Thanks Attachments chip_zps9eea1c31.jpg 59 KB · Views: 96
3 3.8L V-8 eater Well-Known Member Joined Jul 22, 2006 Jan 14, 2017 #2 It's a Bob Bailey's extreme chip...You can contact him here on the board..... Give him the letters and numbers on the chip and he can provide details.....
T TurboSmart Member Joined Nov 6, 2013 Jan 14, 2017 #3 Calling Mr Baileys!! Extender extreme for sure but for what size injectors? There is no Y listed for injector size...
3 3.8L V-8 eater Well-Known Member Joined Jul 22, 2006 Jan 14, 2017 #4 Do a search for Turbo Bob and send him a PM AKA "the mad scientist"
E Eric Stage I TurboTweak Guy Joined May 25, 2001 Jan 14, 2017 #5 "Y" is for 80lb Siemens high impedance Extender Extreme Stock data stream 80lb Siemens hi-z 93 octane 16-18psi boost 800rpm idle Rev F
T TurboSmart Member Joined Nov 6, 2013 Jan 16, 2017 #6 If thats the case... The installed injectors are 75 delphi. Could that difference cause rich mixture all the time? Thanks for the iD!!!
