This build started with a brand new 109 block standard bore 4.1l stroker ...forged rotating assembly....girdle... BHJ balancer jw flywheel ...rjc oil pan ..lt1 starter...rjc billet pullies and alternator bracket comes with accessories..comp cams hyd roller 218/212 ...champion cnc iron head... harland sharp shaft mount 1.65 rockers ...buick motorsports valve covers..champion intake manifold ...accufab 70 mm throttle body....race tronics inj harness ...siemens 80 lb low z injector...tr6 ignition...atr style ss 3 bolt headers with 3 inch dp.... precision turbo 6776 water cooled dual bb..made 600 rwhp at 25 lbs on dyno...5000km on entire build...selling as a turn key package....can b seen running...currently runing in the car .... located in pickering ontario
$13 000 usd
$13 000 usd
