BUICKTIME
just another member
- Aug 11, 2001
ALL PARTS ARE FOR THE 86/87 TURBO INTERCOOLED ENGINES
Recently purchased a new motor combo, so plans have changed leaving me with too many parts that have to go. I will try my best to keep everything up to date and do my best to give an exact description of the used items. Don’t hesitate to ask any questions or make offers. Shipping and PayPal fees (3%) not included. If you are local, parts can be picked up in Oceanside, NY 11572 (please google my location). Thanks for looking.
WANTED/LOOKING FOR: Poly HR Parts Motor Mounts, CNC Ported Stock Champion Intake
Thank you, Mario
CLICK ON LINK (OneDrive) BELOW DESCRIPTION FOR PICTURES
NEW PARTS
1- Caspers 84/87 Dash Harness MATE- NEW_$250 Caspers 84/87 Dash Harness MATE ($305)
FROM CASPERS WEBSITE_ NOTE: This is not a stock Regal dash harness replacement, but rather a "light" version that powers ENGINE FUNCTIONS only. Harness provides tach, oil pressure gauge, and water temperature gauge feeds.
2- 124 Amp Alternator- WAI Part # 7864-5N (mounted but never used)- NEW_$150 124 Amp Alternator- WAI ($210)
3- Coil Bracket, Top & Bottom (top brand new, bottom used)_$50 Coil Bracket, Top & Bottom ($93)
4- Taylor 10.4 MM Spark Plug Wires (for OEM Coil Pack)- NEW _$110 Taylor 10.4 MM Spark Plug Wires ($140)
5- PYPES 3 inch Header Flange Polished 304 Stainless_$20 PYPES 3 inch Header Flange
USED PARTS:
6- Relay (Passenger Side) Bracket- complete with stock MAP, ESC, fuel & a/c relays (small puncture in bracket) _$120 Passenger Side Relay Bracket
7- Stock Valve covers (ok condition)_$50 Stock Valve covers
8- PAC ALKY Control (only what's in the pictures)_$60 PAC ALKY Control
9- Wastegate Adjustable Actuator (#1011-144)- Heavy Duty 18-30 psi- USED_$70 Wastegate Adjustable Actuator
10- OEM Aluminum accessory bracket, painted black (bracket was repaired, welded on bottom right)_ $75 accessory bracket
11- Center Console Chrome applique (not in the greatest condition)_ $75 OBO Chrome applique
12- Auto Meter Phantom Series, Volt & Trans temp gauge w/twin gauge pod (NO sender, Some nicks on bezel, but otherwise good condition)- USED_ $60 Auto Meter Volt & Trans gauge
13- used VDO Oil & Water gauges (NO pod, senders or wiring)- $20 VDO Oil & Water
14- Russell Performance Hose Sleeving Kit (just what you see in the pics)- $15 Russell Sleeving Kit
15- Valve Cover Load Spreader bracket (NA 3.8)-NEW _FREE Load Spreader (NA 3.8)
Free with any purchase above if you want one, just ask.
Heater pipe to intake flare to NPT adapter (hard heater pipes to intake fiting)- FREE Heater pipe adapter
SOLD- RED ARMSTRONG double pumper with generic 4 lb. hobb switch (less than 500 miles)_-SOLD
SOLD- Power trunk motor and wire- USED- $25 -SOLD
SOLD- Harland Sharp Roller Rocker 1.60 (prt# S60360K)- NEW_$690 -SOLD
SOLD- VDO GPS Speed Sensor (Part # 340-786)- NEW -SOLD
SOLD- Pwr Steering Pump (pump only, mounted but never used)- NEW_$120 -SOLD
SOLD- RJC 3 inch DP with Dump pipe NEW -SOLD
SOLD- GN1 Injector Harness- NEW -SOLD
SOLD- PTE Oil Relocation Kit- NEW -SOLD
SOLD- Motor Mounts Stock replacement- NEW -SOLD
SOLD- PYPES RACE PRO MUFFLER -SOLD
SOLD- Melling K-20IHV High Volume oil pump kit- NEW -SOLD
SOLD- DEEDS Multi Boost Stage Controller brain & vacuum sensor only -SOLD
SOLD- Casper Knock gauge (2nd GEN)- NEW -SOLD
SOLD- T-Bolt Stainless 3 or 3.5 inch clamps- pack of 6 (mix and match), Made is USA- NEW -SOLD
Thank you, Mario
NEW PARTS
USED PARTS:
