I can see a problem with mounting the nozzle on top of the pipe with hood clearance in some applications. Mounting it on the side of the pipe ... passenger side... between the pipe and turbo.. should pose no issue.
HTH
Now if you mounted it there.. only solutions is weld the hole shut, replace pipe, or install a plug. But I wouldnt recommend the plug solution.
