$9000 CAD - 1 week only - 1987 Turbo Buick in Ontario
I will let this car go for $6500 US ($9000 CAD) up until next Saturday Sept 20th. I leave for Australia on the following day and would like it out of the driveway before then.
If it does not sell before then, I will bring the price back up to $10,000 CAD and it will sit in my parents driveway until it sells.
The web site for this car is:
http://regal.greywyvern.com
DESCRIPTION: The car is in excellent condition, never driven in the winter since 1997 (that is when I bought it) and hardly ever driven in the rain. I am the second owner. It is painted maroon with a maroon interior. Email me at jack@huisman.com with any questions.
Asking $10,500 Canadian OBO. MUST SELL!!!!!
BODY:
151000 miles on body (243000 KM)
Maroon paint, has been repainted
T-Tops
Excellent body
Car has been oil sprayed (Krown)every year since I have owned it (1997) and was last done Nov 2002
Stock re-finished rims
ENGINE:
25000 miles on rebuild (40000 KM)
1987 3.8 SFI Turbocharged engine rebuilt to factory specs in 1997 at 127000 miles (204600 KM)
TE-44 Turbo with polished compressor wheel housing bought new in 2001 (6300 miles on it now - 10000 KM)
40# Injectors (6300 miles on injectors - 10000 KM)
Jay Carter 93, 100 and 110 octane chips for 40# injectors
SMC Alcohol Injection Kit
Adjustable fuel pressure regulator
High flow fuel pump
Hotwired fuel pump with Casper’s kit
K&N cone air filter
Chrome MAF pipe
Valve springs replaced in 2002 with LT1 springs at 147000 miles (237000 KM)
RJC Power Plate
Heavy duty intercooler hoses and clamps
Adjustable wastegate
Engine tie down strap
AC Delco battery
Fuel pressure gauge
Passenger side valve cover breather
AC CR43TS Spark plugs
COOLING SYSTEM:
Re-cored rad in 2002 from CAS
Throttle body lines blocked off
160* Thermostat
BRAKES:
Converted to vacuum system
Line lock
Rear S-10 wheel cylinders
Adjustable proportioning valve
Turbo Trans AM vacuum block for extra vacuum port
SUSPENSION:
BF Goodrich 235/60/15 fronts
BF Goodrich 275/50/15 rears
All body bushings replaced and missing ones installed
Front springs replaced with stock springs
Rear springs replaced with variable rate springs
Bilstein shocks in front
Competition Engineering 3-way adjustable drag shock in rear
Boxed upper and lower control arms
Airbags in rear springs
Pinion Snubber
Drive shaft loop
Front frame braces
Rear seat braces
Rear end is stock and is posi
EXHAUST
High flow catalytic converter
Dual 2 ¼ Dynomax Ultraflows
Stainless steel tips
INTERIOR:
No power windows, locks or antenna
No cruise control
Power trunk
Casper’s knock gauge and VDO boost gauge mounted on A-pillar in a gauge pod
Casper's audible knock sensor
VDO Oil pressure and water temp gauges in a T-Top gauge pod
Torque converter and fan switch
Interior is perfect, no rips or tears.
Air conditioning blows cold
GM appearing Tape/CD/AM/FM radio
Kenwood 4x10 rear deck speakers
T-top bags
Tinted windows
Lighted rearview mirror
ALSO INCLUDED!:
Tire Pressure gauge for measuring air in airbags
Car cover
Fire extinguisher
“The Club” steering wheel locker
Chilton manual
BODY:
T-Tops
Excellent body
ENGINE:
High flow fuel pump
K&N cone air filter
Chrome MAF pipe
RJC Power Plate
AC Delco battery
Fuel pressure gauge
COOLING SYSTEM:
160* Thermostat
BRAKES:
Line lock
SUSPENSION:
Pinion Snubber
Drive shaft loop
Front frame braces
Rear seat braces
EXHAUST
INTERIOR:
No cruise control
Power trunk
T-top bags
Tinted windows
ALSO INCLUDED!:
Car cover
Fire extinguisher
Chilton manual
