12.66@111.51
incubus2432
Douchebag
I got four runs at the track with my new combo. Made improvements every time and I think it's got more in it. I'll be on drag radials and locking the converter next time out. But for now here's my best....
R/T - 0.89
60ft.- 2.15
1/8 - 8.31@90.28
1/4 - 12.66@111.51
Fix those 60' times and you'll be seeing MUCH improved timeslips.
Drag radials, air bags. Dont do anything else until you get these and work on your launches!
I went 8.003 and 12.65 in the 1/4 at 107.69 with the stock turbo and a dutt neck intercooler on pump gas and alky.... but with a 1.71 60' time (MT drag radials)...
I agree... you get your 60' dropped with some traction.... mid 11's are there for sure....
what is your GTB61**** equivalent to? i went 12.6@103 with my TA-49 with a very very poor tune o2's were in the 1000s lol, that might be why it was breaking up bad on the top end and only running 103 lol, and that was on 19# of boost, and 22 degrees of timing.
,Dan
,Dan
I'm not sure what an equivalent turbo would be. I'm probably a hair on the rich side but I'm happy with the tune. Along with traction (obviously) technique is my main problem.....just figuring out how the car likes to be run. I believe it has a 117MPH pass left in it on street tires so once I melt those off and pick up some drag radials for some traction mid 11's should be at hand.
R/T - 0.89
60ft.- 2.15
1/8 - 8.31@90.28
1/4 - 12.66@111.51
Tires, man- get some traction! Get that 60ft down to 1.6-1.8 and you'll be in the 11s ( about 11.70s).
Good numbers!
