1987 Buick Grand National T-Top
1987 Buick Grand National 3.8 Turbo in GREAT condition. I run it on the street, as well as on the drag strip. Following are details regarding the car:
* 62,800 miles
* Motor:
* .020 JE's with Calico Coatings Ceramic Tops/Teflon Skirts
* Stock Rods with Polished Beams and ARP Bolts
* Stock GN Crank .010/.010 Cut to .0016-.0018" Clearance
* Billet 1/2/3 Caps, RJC Billet Girdle with Crank Scraper, ARP Studs
* Clevitte 77 Main/Rod Bearings, TA Cam Bearings
* Crane 210/214 Billet Roller Cam
* PTE Cam Retension Hardware Upfront
* Buick Tchain (as per roller kit)
* BHJ Harmonic Balancer with Ring, JW Flexplate (sfi certs A ok)
* Oil Pickup and 20 Bolt Oil Pan Installed
* Balanced and Blueprinted Assembly
* Champion Iron Heads and Intake te45a Turbo
* Transmission:
* Vince Janis
* Suspension QA1Adjustable Shocks & HR Parts Upper and Lower Control Arms
* Extra Wheels with Slicks 28 X 9
* Removeable Rollbar Side & Back Bars
* FAST XFI installed by Bill Anderson
* Interior Gauges
* Oil Pressure
* Water Temperature
* Tack
* Knock Detector
* ATR Single Shot Exhaust
* Show Quality Paint Job in 2006 with all new T-Top Gaskets/Seals
* Precision Front Mount Intercooler
* 3500 Torque Converter
* Dyno Tested - Max Power = 520.34/Max Torque = 531.62 under a VERY light tune
* Extra Parts, including Stock Short Blocks with Heads
I am sure there is much more about this car that I am forgetting; however, if you have any questions, please call me at 240.727.6815.
Price is $18,000.00 or obo.
Kevin, I thought of you tonight when having dinner. Was wondering if you had seen the Hot Street class that was getting started and thought you and your car would be perfect for it and then see your car is for sale, kinda weird.
Guys this is a very nice car owned by a guy that is the same.
Take care, Kip
