BuickCamaro
- May 13, 2002
Degreed the cam and now the motor pops in the upper RPM's but will build 15 PSI of boost. What chart do I need to look at on the Fast system and is this a lean condition in the upper RPM's or just not enough timing. This happens in all gears . Or could I not have enough spring pressure on the valves and they are opening easier in the upper RPM's under that amount of boost. Car starts fine and doesn't pop on the low end at all!!!! Any help would be greatly appreciated!!!!!!!
