79# injectors how fast?
79# injectors
Wow I was hoping at least high 10's with a good ext. pump!
maxxed out
has any body maxxed these out or used them with 100% e85 ? I figured by now somebody had give these a try!
I went 10.4 on 83, but that was with a A1000 pump(small) they are good for about 500rwhp
a1000
tom, do you think the a1000 was out of steam, or were you running out of injector. I see you have a weldon now, I'm assuming that made a diiferrence?
I think the pump was tapped out. When I made the pump change I also made an injector 120lb change so I really can't say for sure
I think you should consider the 83s min, maybe even the 96s.
