I need help just finished my 92 ty put in a new motor everything is good but when u put in gear it cuts off in N or P it will run all day plz help???????
I had the same issue with my Turbo Regal. If i gave it gas, I could keep it running, but it was almost impossible, and I had to give it plenty of gas while driving. If I let off, when taking an on ramp, it would die doing 50. It turned out that my cam sensor was out of adjustment. I don't know the ignition etc set up of a Typhoon, but at least this will give you a TTT.
Ignition module check checking cam sensor now the funny thing is the truck will start with brake vac line off intake but will also shut off once pluged in the same shutter when i put this thing in gear the turbo regal is much easier to work on can any1 else HELP???
