Theres no vaccum leaks under the hood, hard lines are good. Vaccum ball is new, both check valves good, the 3-way black check valve is new. The bi-level works after about 5-10 minutes and I get partial air through the vents at times, but 90% of the time its just defrost/floor. From what I can see through the glove box everything is hooked up. What next??? Its getting hot down here!!!
thanks
pat
thanks
pat
