add fuel or alky
CanGN
no knock in first and second gear, when it shifts to third, O2s drop to low 700s and see a bit of knock then it goes away as 02s come back up...should I be adding some fuel to the chip or turn up the alky a bit. this is at about 23# boost..thanks
steve
get your base fuel set with the correct a/f ratio , then tune the alky for knock
You need to post in the alcohol section...all the true alky-holics are there and can answer all your questions.
They usually dont let those inmates out... they would run amock in the other sections.;)
