STF420@comcast.
- Oct 6, 2003
I am testing my alky pump (Razor Kit). W/Razor test kit. With the controller on 8 & Map simulator on 30psi.
The gauge fluctuates very fast between 130-150psi (avg. 140psi) So fast you real can not see the needle. Is this normal? Or should it be 140-160psi (avg. 150psi)
I usually need to run my controller 7-8 to keep knock away.
Thanks, Mike
Thanks, Mike
