Another wire question
Discussion in 'Electrical & Wiring' started by turbotrix2004, Mar 20, 2017.
  1. turbotrix2004
    turbotrix2004
    Expand Collapse
    Nov 2, 2013
    255
    14
    Offline
    Pulled the carpet to add sound dampening and insulation and saw this wire that runs from the ecu harness to the center console light. Does this look correct?
    [​IMG][​IMG]
  2. bpman1234
    bpman1234
    Expand Collapse
    Jan 24, 2011
    1,410
    53
    Offline
    I believe you have a chip that Came with that wire to be hooked up to that wire you see .so you can make tunning adjustment's in certain perimeters.
    Sent from my LG-K373 using Tapatalk
  3. turbotrix2004
    turbotrix2004
    Expand Collapse
    Nov 2, 2013
    255
    14
    Offline
    That wire hooks up to the console light in the pic
  4. turbotrix2004
    turbotrix2004
    Expand Collapse
    Nov 2, 2013
    255
    14
    Offline
    Nobody knows?
  5. DCVING 6
    DCVING 6
    Expand Collapse
    Jul 11, 2002
    3,606
    71
    Offline
    I have my carpet out right now and can say mine doesn't have that wire.
    Sent from my LG-D850 using Tapatalk
  6. turbotrix2004
    turbotrix2004
    Expand Collapse
    Nov 2, 2013
    255
    14
    Offline
    ‍♂️ that's weird it looks like a factory wire but the way it's hooked into the console light is definitely not factory
  7. GNVenom
    GNVenom
    Expand Collapse
    Jan 6, 2002
    1,804
    199
    Offline
    Factory didn't use Scotchlocks.
    Factory didn't use plastic spade terminals.
    Factory didn't put wires outside of the main harness bundle.
    Some sort of trigger for some function, possibly the ECM had been modified as well.
    Proceed with caution, but I'd personally remove it and drive the car, look for any variation in its operation.
  8. turbotrix2004
    turbotrix2004
    Expand Collapse
    Nov 2, 2013
    255
    14
    Offline
    Problem is I'm in the process of switching over to fast xfi so the car don't run right now. I know the connectors and such aren't factory but the brown wire looks like is it's a factory wire that's supposed to be hooked up to the ecu connector. Does anyone have a wire chart of that connector?
  9. DCVING 6
    DCVING 6
    Expand Collapse
    Jul 11, 2002
    3,606
    71
    Offline
    What pin # in the ecm does it go to?
  10. turbotrix2004
    turbotrix2004
    Expand Collapse
    Nov 2, 2013
    255
    14
    Offline
    Looks like 11
  11. turbotrix2004
    turbotrix2004
    Expand Collapse
    Nov 2, 2013
    255
    14
    Offline
    Nobody knows??
  12. GNVenom
    GNVenom
    Expand Collapse
    Jan 6, 2002
    1,804
    199
    Offline
  13. turbotrix2004
    turbotrix2004
    Expand Collapse
    Nov 2, 2013
    255
    14
    Offline
    It says Manifold air temp sensor, why the hell would that be hooked up to the light?? Weird
  14. turbotrix2004
    turbotrix2004
    Expand Collapse
    Nov 2, 2013
    255
    14
    Offline
    Actually it's d11 not used, wonder why that was wired like that
  15. turbotrix2004
    turbotrix2004
    Expand Collapse
    Nov 2, 2013
    255
    14
    Offline
    Thanks gnvenom!!
Share This Page
