anyone have a picture of the correct bolt for the front of engine
arista5
Sold, and Replaced
Staff member
I have a CAS V4 and am going to go FMIC
One of the bolts holding the bracket on goes into the block and holds water and i couldnt really say much more than that except its low in the compartment and on the pass side.
does anyone have a picture of this? i should have all the original bolts that were here but just dont know which to use.
any help is appreciated
yes i know its vague but i didnt get to the car today to snap a picture. I will tomorrow.
I didnt receive a stainless bolt for my car that you replace the original bolt with that goes into the water pump. I just pulled the original out then bolted on the mounting bracket.
I dont have a picture of my bolt since it's installed on the car. But i know it's about 5-6 inches long and has threads on the end for about an inch.
-Adam
thank you i can pictue that bolt in my head and also know where in the box it should be
When installing the bolt, remember to put some water proof sealent on the threads so there is no leaks!
-Adam
