I believe P-trim and larger turbine wheels will use the larger shaft.
As Intercooler said, TE-62`s (w/ p-trim) experienced failures for some time. I ran a 62 that is 4 years old and it worked flawlessly. But, anything larger than the 62 will probably be of the big shaft variety. The TE-62 uses as 59mm wheel. Where as the 63, is a 63mm. Must be that the extra mass causes problems? My guess, any how.
Brian
