Here we go. . . . . .
O.K. Ya ready? ? ? ?
Good news: came up with a new tool for bleeding my brakes Take 1 8mm 3/8 drive cheap socket, epoxy in a couple feet 1/4" clear plastic tubing to the ratchet side, grind opposing sides of the socket flat so you can wrench on it, put a small o-ring in the end to seal to the bleeder screw and bleed away.
Bad news: Too much air in the lines it isn't working
Good news: Porsche racing prep shop out behind my work has compressor-assisted vacuum bleeding system they'll let me use.
Bad news: My downpipe and the exhaust housing for my TA-49 are still sitting in their office after being "sent out two weeks ago"
Good news:I put my downpipe and TA-49 in today (after I polished the intake-side housing)
Bad news:They aren't coated, nor are they going to be anytime soon
Good news:Brakes bleed great, lots of air out of the rear lines and some out of the fronts. I decided to bleed the system twice and the pedal is rock hard.
Bad news: While having my head stuffed in the drivers side wheel well bleeding the brakes I noticed a crack in the drivers side header.
Good news:The car sounds awesome with a straight downpipe exhaust! ! !
Bad news: I know this 'cause the "test" pipe that came with my exhaust system isn't 3". DUH!
Good news: Car stops on a dime and doesn't seem to prematurely lock the rears.
Bad news:Can't test on the street 'cause the exhaust sounds like a offshore race boat.
In summation it still brings a smile to my face just to get the car down off of the jack stands and if you don't have any patience or if you have too much of a temper, DON'T DRIVE A TURBO BUICK!
