G gusszgs Active Member Joined Dec 9, 2007 Jun 1, 2017 #1 Anyone know who makes this boost controller and if it's a decent piece? Had it for years but never used it as I always seemed to have good luck just using the adjustable actuator for boost control. Attachments IMG_1395.JPG 1.5 MB · Views: 179 Last edited: Jun 1, 2017
B Boost231 What's An Intercooler Staff member Joined May 26, 2001 Jun 1, 2017 #2 Looks like a turbosmart unit but might be a knock off Sent from my SM-G935T using Tapatalk
G gusszgs Active Member Joined Dec 9, 2007 Jun 1, 2017 #3 Feels decent enough when adjusting the dial.........has little clicks to it. Also can be mounted but I have no idea where
T turbo2nr loading... Joined Aug 28, 2004 Jun 1, 2017 #4 I would still use the oem metered oriface found in the Grey T connector. Stock solenoid is optional. Then you bleed some pressure in the line going to actuator. Add this gizmo just before the actuator.
