how long are the boost hoses. longer hoses have been known to induce lag and cause spikes. if this is not the case, do you have a bleeder valve. if so i believe they have been known to spike. finally, if you dont like the spike you could try setting the BC a couple lbs. under what you desire. you wouldnt risk overboosting but you wont get the full boost you want in the end.
