My brake light eluminates for a split second when the brake pedal is first pushed. Car has 14,000 miles, brass proportioning valve installed 2 years ago. This started this spring after storing the car for the winter (don't know if there is a relationship). the car stops fine and there are no leaks anywhere. No corrosion anywhere ( CAR IS LIKE NEW INSIDE/OUT ). PM pressure switch was replaced under recall in '98. Have a "Jumper valve" installed to the rear brakes and soft shoes, but all was working perfect when the car was put up for the winter. Might try bleeding the brakes, but I suspect maybe it's time for an Accumilator. Any input would be helpful. Thanks Brian
