This cam sensor setting is driving me nuts!!! I reset it with the caspers tool and made sure the engine was 25 degrees past tdc. Went to start it and just kept cranking. The window was pointing towards drivers side headlight. Turned it a little and it started but ran rough. Shut it down and changed the plugs because they were soaked with gas. I'm going to retry setting it today with the fresh plugs. I'm thinking maybe remove it again to try to get the window to point directly to the drivers side instead of towards the headlight. Any ideas/thoughts to help me out are very appreciated. I'm getting to the end of my rope here. Thanks, Tim
