I am doing my valve springs and have everything off I am wondering if I need to put all the heater stuff back on....
I do not need or really want heat in the car and if I can keep that rail out it looks alot better under there. Not to mention makes it easier to put back together after the valve springs are done...
What if I was to block of the heater lines at the firewall then run the hose from the waterpump straight into where the rail mounted below the plenum?
Thanks much for your input!
Gary
Gary
