Okay, installed razors alky today and the install went very smoothly. I actually spend more time cleaning up the previous owners messes. I got everything hooked it, did the tests to make sure the lights were working, etc., etc. Drove over to Napa auto parts to get a new flasher relay for my turn signals and the car died in the parking lot when I was getting ready to take off. I thought, no big deal. I had the door open all day and the battery is low. I got a jump from the guys. I then drove the car over to Rhodda paint to get some denatured alcohol for the alky tank. As I was driving over to the Rhodda I noticed the heater controls were making a clicking noise, and a squeal (I've got the pushbutton style controls). I pulled into the parking lot and the car died. I got a jump again and noted the scanmaster said battery was at 8.8 volts with the car running. I also saw the scanmaster indicating the car was going to 13.4 degrees retard, back to 0, 13.4 degrees retard and back to 0 over and over. I limped the car home and I've got it hooked on the battery charger.
I do not believe I have ANYTHING improperly grounded on this alky control install. I will double check everything, but can you guys think of anything it could be???
Heck, I don't know, maybe the alternator is going out and it's not charging the battery, but what about the timing retard? The only time I've ever seen it do that was when my crank sensor was going out and it would do that retard-zero, retard-zero thing....
