Car stalls when place in gear with A/C on. What should the IAC counts be?
GNVAIR
I recently fixed my A/C (and boy does it work great! LOL)
Anyways, I have a problem that started cropping up once I started using the A/C. If I leave the A/C on when I start the car it will idle at about 1300 and gradually drop down and then stall out. I usually have it set to idle at about 900 rpms.
Now, it will idle really low with the A/C on. I am just confused what the IAC counts should be.
What should they be under normal idle?
With the A/C on?
At a steady cruise?
Any help would be greatly appreciated. TIA!
Not using conventional chips, I have to guess a bit...
But, at idle, fully warm engine, in Park, AC off.... counts should be 15-30....some would say 10-20 and a few years ago it was 20-30. Factory specs go higher. Lower the number, the less the iac does.
I would guess in drive with the ac on, the counts should be above 50 but the specs above are what really count.
I will try it out tomorrow since the problem only occurs when I have the A/C on and try to start the car.
I had a stalling problem once - turned out the iac was at 75 warm in gear. I run it at 0 now - no problems.
Is ECM showing an AC request? If not, its not compensating for the load and can stall. If its NOT showing the request, go to the low pressure switch, I believe one side has 2 wires, one goes to the ECM and tells the ECm "Excuse me, the owner put the control on" then the ECM looks to see if the cars been running a certain amouint of time, the car isnt WOT, then hits the AC cutout relay to turn on the compressor, and bumps the IAC the specified counts.
If you are running in at zero in gear, then you have turned the iac in so far that it no longer functions and may create a "too fast" idle.
I just checked and on the way back from lunch with the a/c on and the car warmed up, the IAC counts were 45-48 in gear.
With the a/c off and the trans in gear, the counts were 25 with no fluctuation.
Jim, I am not sure how I would check the AC request. The only scantool I have here is the Scanmaster. I can borrow my buddies Snap On scan tool if needed.
I checked the counts again last night and noticed that in Park with the a/c off, they were 0 and with the a/c on they were 7-10
I also noticed that my TPS is now .48 where it had always been set at .42. Could I possibly have a TPS that is going bad and throwing the IAC counts off?
Lee, I have a very similar situation as yours and I was thinking the same thing. My iac's dont seem consistant at all. I just replaced my tps, and it didnt help a bit. Thinking about replacing the iac valve now. Can it "go out" guys?
