No i pulled the snubber of when i installed the umi control arms .
I was fishing on the slip % ,I don't think its was all that bad,but was hopping to get some good input on the numbers.
every one has helped a lot.Its seems like all of you are saying ,don't lay back on the power but fix the traction problem.
looks like the convertor is not really a problem at this time.
Option #1 Hoosier has a 10 in. that will fit vary nice on my existing wheel,No mods
Option#2 Hoosier 10.5 is just a hair big with out rolling the finders,East wood has the finder roller,and i can rent it out to all the Honda people on the island. its 10.2 and a little harder rubber than the 10, something to think about and stiff sidewall
Option #3 MT has the new 275-60-15 ET street Pro 9.8 and will need finder work. same wheel combo 4 in. backspace might be to much but can use a spacer.
Option #4 MT Pro bracket radial 28-10.5-15 I need to steep up to a 10 in. wheel and finder work its 10.2 contact and a little harder than ET street.
Any one of these should help fix the 60.and if I fix that ,MPH will go up in both the 1/8 and 1/4 and slip should go down.
Whats my best option? Looks like its going to be some late night number crunching and more research.and more ???
