Correct wilwood master cylinder for hydroboost
260-8556 is what I used. It comes with a spacer to use if you have the short pushrod booster. I had to turn down the spacer slightly with a drill because it was keeping just a little preload on my brakes. Couldnt feel it but they were smoking in the front after an hour on the road.
260-8556p is what i used with c6 zo6 and hydro boost. had same issue as HouTX87 with brakes draging.
