CRUZ Performance NEW product throttle body vacuum block delete kit
III'S 87 GN
Remove that 30+ year old plastic factory throttle body vacuum block that is ugly with all
of its hard lines and leaking rubber lines going to it.
This kit is easy to install and comes with the majority of the pieces needed to do the conversion (example may need 1/8 inch to 1/4 inch hose adapters)
CRUZ Performance NEW product throttle body vacuum block delete kit includes
1/2 inch plenum spacer (fits under stock hood)
2 new plenum gaskets
stainless allen head mounting bolts for plenum
throttle body delete plate
CRUZ Performance vacuum block (5 x 1/8inch ports, 2 x -6 oring ports)
7 x 1/8 push lock fittings
2 x -6 oring fittings (specify female 1/8 inch hole or -4 male AN)
20 feet heavy duty black nylon push lock hose
$249 complete kit shipped to US
ADD $25 for swap to 1 inch plenum spacer for performance and addition of inlet temp sensor
CRUZ Performance plenum spacer, vacuum block and throttle body delete plate
made in Florida, USA.
Please call ,text or email
813-399-0409
don@cruzperformance.com
www.cruzperformance.com
https://www.facebook.com/CruzPerformanceTampa/
  1. cruz-performance-vacuum-block-delete-kit-all-parts-jpg.294984
    cruz-performance-vacuum-block-delete-kit-install-1-jpg.294985
    cruz-performance-vacuum-block-delete-kit-install-2-jpg.294986
    cruz-performance-vacuum-block-delete-kit-install-3-jpg.294987
    cruz-performance-vacuum-block-delete-kit-install-4-jpg.294988
    cruz-perormance-logo-with-vendors-jpg.294989
I have a few on a blog post I did when I installed it. I made a bracket and mounted the distribution block alongside the plenum.
http://blog.andrewdscott.com/?p=177
Something I found out was that using gaskets on the spacer didn't work very well. It leaked in the back near the bolt under the coilpack. I ended up using Right-Stuff to seal the spacer to the manifold and the plenum to the spacer. The location of the IAT sensor hole is also not compatible with the stock throttlebody, so if you're using the stock TB, have them drill that hole in the side or the back, not the front.
The IAT hole is on the drivers side on my new kit. It looks like it was on the passenger side with yours?
Chuck
I have my kit installed which everything seems to fit as it should... but a little upset as I received a plain Jane vacuum block VS the nice anodized “Cruz performance” engraved pictured above.. otherwise all seems well. We will see how it performs here in a couple days!
I just ordered the vacuum block replacement. Why is the nice black block with the engraving advertised but you ship out a plain one???
Thats false advertising for sure. I'd love to ship the one I got back to you guys and get the black one that's advertised on your website.
Did you call them and ask them directly?
Same thing here.
