84BuickGNYorkPA
Daily Driving Buick V-6 Turbo's 1979 - Present
- Jul 5, 2005
New fuel pump went in a few weeks ago, pressure still isn't going up 1:1 ratio, replacing fuel filter next, hope that's it...
Who did the transmission work?View attachment 298432 View attachment 298433 View attachment 298434 View attachment 298435 Had tranny rebuilt with billet parts
New converter 9.5" Pro Torque 3000 stall
Had up pipe polished
New wheels and tires
Sent from my SAMSUNG-SM-G900A using Tapatalk
Ok, good. Same guy Jim recommended to me. Thank you.Michael's Transmission and Auto
In Waterford, NJ
Jim Dunn recommended him.
He did a great job and is fairly priced.
Parked, inoperative. Currently chasing a no start condition.
I'm going slow with this, I want to be thorough. I already squeezed some female pins on the connectors to make better contact. Some look rough. Thanks.Check the connections, I've replaced a bunch of mine on the wiring harness. Caspers Electronics has all of them.
Sent from my Spaceship.
I don't think you had "excess voltage". I had two hangers fail within 6 months of each other. So far the Racetronix harness is working for me too. You can also eliminate that bulkhead by splicing new wires together and running them through a rubber grommet on top of the hanger. Maybe seal it with a dab of silicone. Nick Mchale said he has seen many failures lately, too.Chuck I have those lines on my car. Far as my current status; had fuel pump issues right before Cecil. Wiring in the tank burned up from excess voltage from the hotwire and stealth 340 pump. Located an upgraded racetronix intermediate harness, fixed it and broke down on the way there due to me pinching the return line putting the tank back in. Luckily got it corrected, changed the oil and made it to the track. Currently have a head stud leaking coolant that I need to address and a boost leash controller to install before spring.
Any update?Good fuel pressure, injector pulse, ecm power checked good. Spark on only two opposing pack posts. Crank and cam sensors checked within tolerance.
Points to ign module, changed with a known good one, same symptoms.
Gonna attack again tonight with the multimeter. It appears the drivers area bulkhead connector has been disturbed so we'll see.
Any update?
The stock and new replacement stock hangers use wiring that is to small of gauge. When you add in a hotwire and a pump that demands more voltage, the wiring can and will fail. Surprised it didn't burn the car down. Racetronix stopped selling the upgraded harness for the pump hanger. Was lucky a friend had one for a TTA that I made work. Only solution now is to buy the complete Racetronix pump/hanger that includes all new wiring.I don't think you had "excess voltage". I had two hangers fail within 6 months of each other. So far the Racetronix harness is working for me too. You can also eliminate that bulkhead by splicing new wires together and running them through a rubber grommet on top of the hanger. Maybe seal it with a dab of silicone. Nick Mchale said he has seen many failures lately, too.
