I'm really trying to figure out what is going to be the best route to go with my rear end. I'm going Ford 9" setup. I've heard stay away from lockers because they are annoying on the street (locking and unlocking all the time). I've also been told not to do a spool. Is there anyone or has anyone you know used a Detroit Truetrac limited slip diff with their 9" or any rear for that matter? I see it doesn't use clutch packs, rather all gears and is maintenance free with no wearable items. They have a 31-spline version available. I'm just wondering how much power they can handle. My car will be 95% street driven with occasional trips to the track and I want it to be able to handle a high 9 second pass if needbe. Would this be a good unit?
"Detroit Truetrac was the first helical gear differential ever introduced into the automotive aftermarket. It remains the leading helical gear-type limited-slip differential in the industry. Its proven helical gear design eliminates the need for wearable parts, resulting in maintenance free traction. Recognized not only for its durability but also it's smooth and quiet operation.
Power transfer is so smooth; it literally goes unnoticed by the driver. Engineered to work efficiently in front and rear axles. No maintenance - Just Traction!"
Detroit Locker #357-913A586
# 1976-87 Ford Car/Truck Truetrac Differential 31-Spline Axles
# 9" Diameter Ring Gear
# Fits All exc. 2.72 Gear Ratios
