Dusty, I'm looking for a converter for my 78 malibu drag racer...I'm currently footbraking the car at 2500 rpm's, and the converter is flashing up to 4xxx. I'm going to go with a transbrake w/2 step. Vehicle weight is 3024#, and I weigh 225#. 1-2, 2-3 shift 6500 rpm's. Track is 1410' altitude. Currently footbraking with a GM40 4000 stall 10" converter. I will be running super-pro..
Here's a video. I'm coming out on the hole soft on that launch.
1978 Malibu, 10.61@126.- Video
Current combo:
454 .060 over
GM forged crank, Eagle rods
GMPP alum rectal heads, 2.19/1.88 valves
SRP pistons, 12.4:1 final comp
Lunati solid 259/267, .625/.625, 110 LSA
Crane Gold roller rockers
CSR electric water pump
Vic Jr intake, Holley 950HP carb
Mallory comp 250 pump, comp 500 filter/regulator
MSD 6AL, blaster coil
GZMS vacuum pump
Th400, Cheetah SCS shifter
Hughes 4000 stall converter, manual/reverse valve body
Ford 9" rear, 4.10 gears, spool
rear disk brakes, BMR u/lca's, TRZ anti-roll back.
supercomp headers, ultraflow 12" bullets
10 point cage
M/T 28x10.5 ET slicks.
Let me know how to get ahold of you so I can figure out how to purchase a converter. Also looking for a recommendation on what converter/rpm. Thanks.
Current combo:
454 .060 over
GZMS vacuum pump
10 point cage
