E85 vs. alky
Discussion in 'E85 Technical Forum' started by Pittsburghkid, Nov 10, 2013.
  1. 87-WE2
    87-WE2
    Expand Collapse
    Back in business!!
    May 17, 2011
    1,127
    105
    Offline
    Here's my cold start just now. It's about 40*F here outside. Inside the garage it's about 50*F evidently. It's been about 3 weeks since I started. Wondering if the Optima had enough juice to get the job done, but it did OK.
    I'd have Eric look at your chip!
    • Like Like x 2
  2. turbo89
    turbo89
    Expand Collapse
    Apr 11, 2002
    1,868
    262
    Offline
    My GN fires right up even in the 30's .. E85 isn't your problem ... might want to look into that battery .. when a battery is weak on these cars ALOT of things Suffer...
  3. TT/Ameasap
    TT/Ameasap
    Expand Collapse
    The White Blur
    Jan 31, 2002
    4,756
    408
    Offline
    I fired mine up after 2 weeks of freezing weather and it was 40° out today. Cranks a little more than on gas, but for the most part, it's good.
  4. larry33kc
    larry33kc
    Expand Collapse
    Aug 19, 2001
    1,430
    58
    Offline
    87 WE4 I wish mine stated that fast. I have BS3 and it takes a lot on cold start
  5. bison
    bison
    Expand Collapse
    Moderator
    Staff Member
    Dec 19, 2005
    16,375
    1,213
    Offline
    Post cranking voltage
  6. Wahoo
    Wahoo
    Expand Collapse
    Apr 2, 2011
    1,557
    36
    Offline
    I definitely plan to go E85 possibly next spring.
  7. TURBOPOWERED68
    TURBOPOWERED68
    Expand Collapse
    David
    Jan 31, 2006
    6,916
    199
    Offline
    not much of an update but here it is.
    i haven't started the car in over 2 weeks.
    I got a new TTChip and this is the result
    • Like Like x 1
  8. Blaze
    Blaze
    Expand Collapse
    Apr 20, 2005
    451
    5
    Offline
    What pump or pumps are you using?
    What chip are you using?
  9. 87chrisss
    87chrisss
    Expand Collapse
    BLUBYU
    Jan 31, 2011
    2,207
    233
    Offline
    I like Red'S DP i was using an Aeromotive filter tho with stainless steel mircon element. Car had good grounds. I always run a VOLT BOOSTER. I like to check voltage at pumps stock wiring really was marginal to begin with. Good alternator, and a chip from Eric. Before i get the car into boost i would drive with the fuel pressure gauge on the hood and verify fuel pressure rise with boost that should tell you how your fueling is. I def had pressure.
    If your engine combo is good you shouldn't have an issue my car had a stock cam so it really never winded up i kept the rpm's low using 28"tires. Good Trans and Converter set to shift where i wanted. Car ran fantastic. It wasn't that fast but who the hell cares it was more fun than any race car i have ever owned, A street T that can rip tires on any down shift is fun reliable why go a sec or 2 sec faster but have horror stories behind it???
    I really don't know how so many ppl have fueling issues, i basically had a stock car that i would take to the track and run low 7s consistent with almost nothing.
  10. Blaze
    Blaze
    Expand Collapse
    Apr 20, 2005
    451
    5
    Offline
    Cool, thanks for the info.
  11. jay dcpt
    jay dcpt
    Expand Collapse
    Feb 8, 2010
    177
    1
    Offline
    • Dumb Dumb x 1
  12. Rafs-T-Type
    Rafs-T-Type
    Expand Collapse
    Not so Senior Member
    Mar 8, 2009
    2,338
    211
    Offline
    Are you calling my post dumb? If so do you have an explanation as to why?
    • Funny Funny x 1
  13. Wahoo
    Wahoo
    Expand Collapse
    Apr 2, 2011
    1,557
    36
    Offline
    could be an accident with the cell phone, I've probably accidentally done it once
  14. TurboTGuy
    TurboTGuy
    Expand Collapse
    Gray Beard Member
    Sep 24, 2010
    3,106
    796
    Offline
    :D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D
    [​IMG]
    • Funny Funny x 3
  15. deezdad
    deezdad
    Expand Collapse
    Mar 25, 2005
    786
    135
    Offline
    • Funny Funny x 3
  16. TURBOPOWERED68
    TURBOPOWERED68
    Expand Collapse
    David
    Jan 31, 2006
    6,916
    199
    Offline
    My update.
    Went to XFI and i can now switch from an E85 tune to a 93 tune in a few seconds.
    For example i went out to kirbans a few weeks ago, i just ran the E85 low then filled up with 93 changed the fuel setting and drove 200 plus miles with out missing a beat ---- While on 93 i kept it to regular driving no more than 5-8 psi because the timing was still set for E85. and i don't have the ALKY injection hooked up at the moment.
    NOW one thing that i am considering is keeping my Alky injection kit for minimizing/addressing heat soak that my cheap front mount can be suffering from. My idea is to move the ALKY nozzle to the outlet of the turbo so that spraying the ALKY can cool the IC, pipes and intake. A Buick guy also suggested that i can run a nozzle to the inlet of the turbo to help the turbo's efficiency.
  17. GNBRETT
    GNBRETT
    Expand Collapse
    Pelennor Fields
    Feb 8, 2004
    10,511
    145
    Offline
    what exactly is this E85 stuff everyone talks about? CT for some reason missed the bulletin cause there are only 2 fukn stations in the whole state and their both an hour away smh. of course u cross over the line in NY and their everywhere smh. I plan on tuning my Mustang to it and simply buying a 55 gallon drum or two and putting in my garage. my car is already tuned to E85 with the old combo so I have the supporting fuel system to do it.
    but otherwise it will be on pump gas/meth but the meth isn't being used as fuel just insurance. I guess thats the beauty of the V8 and modern technology is one can run pump gas only and make what others make on E85 in a different application. I jus can't imagine the gas mileage tho. it takes 35 minutes to even get anywhere around here. at that rate my tank wud be half empty by the time I got anywhere to cruise.
    I guess its a no brainer if the stations are close and the cost is low tho but not for every day cruising. 30% less MPG is just too steep imo. but then again who drives their TR every day other then Bison....:D
  18. bison
    bison
    Expand Collapse
    Moderator
    Staff Member
    Dec 19, 2005
    16,375
    1,213
    Offline
    Ethanol based fuel will always make more power than 93 octane. You're burning more fuel. Plain and simple. More btu's more power
  19. jay dcpt
    jay dcpt
    Expand Collapse
    Feb 8, 2010
    177
    1
    Offline
    that's exactly what it was. actually really enjoying this thread.
    • Like Like x 1
Share This Page
