Factory Theft System
Joe Reif Sr.
:confused: Has anyone come across this problem ? If so how did you fix it ? The Factory alarm system will not cancel when the doors locks are unlocked with the key or the remote.
maybe the wire came off the door lock on the driverside. take off your door panel and look to see if a wire is connected to the lock. this maybe your problem
No Remote on the factory system. Double check that the code on the SPID label is UA6. If it is than it's factory installed and maybe the fault is in your RKE(RemoteKeylessEntry) installation. If it won't disarm than I'm thinking there is an open in the system.:confused:
