Fast xfi 2.0 calibration file
Toddmc66
Import punisher.
I purchased an other 87 GN with the Fast system. It's running on base settings. It has about 10 different saved calibrations. The 3 preset calibration spots are empty. How do I move them or load them into those positions? I've tried to do this but afraid the engine won't run because when I select one it says WARNING do you want to overwrite the current ecu data.
Any help would be appreciated.
lots you need explained and you dont want to go messing around without knowing what you're doing
call hartlineperformance , 321-610-1500
if your box was from Cal Hartline he may help you , if not buy their support package
