felpro gasket ?
87Ltd
Senior Member
Hi,
I needed the exhaust donut for the downpipe. So I ordered the Felpro Turbo Mounting Gasket Kit ES 72697 from rockauto as it included the donut and some others (I figured I may as well get the oil drain gasket just in case...)
I know where the paper gaskets and donut go. But I'm not sure about the 3 O-ring gaskets.
Just noticed my oil adapter is pretty oily so I'll clean up the area to be sure. But I'm wondering if one of the included o-rings in the Felpro kit is the o-ring that goes bet the adapter and oil pump cover.
Here's a pix of the gasket kit. From the description/pix of box there's 2 big o-rings. And one little one.
http://www.weberpowerproducts.com/turbo-mounting-gasket-set-p/fel-es72697.htm
Kinda confusing as the desciption for the o-rings says 2 of em are for the oil cooler adapter (these are 2 big o-rings). And one is a retainer adapter connector? (there's one small oring).
Thanks in advance.
John
