Greetings all,
Noticed some brake fluid on the ground and when I looked into it, noticed that the resevoir was a little down and brake fluid appeared to be leaking down the firewall were the powermaster is connected. As a new owner, I can only assume that it's the original unit with a new pressure switch and accumulator..Is there a seal or something that can be changed out ?? Any ideas would be appreciated !!! Thanks in advance
JB
JB
