Frame bracing / support
Discussion in 'Safety Equipment' started by TurboJames, Mar 26, 2017.
  1. TurboJames
    TurboJames
    Expand Collapse
    Feb 8, 2015
    100
    2
    Offline
    is there any kits or anything to make the frame stiffer for more support? Ive seena couple things there are just so many buick sites.
    I have a t top and i really dont want to cage it, but id like to support the frame because it lacks support areas. All information recieved i am thankful for!
  2. Gene Van Horn
    Gene Van Horn
    Expand Collapse
    Feb 20, 2013
    618
    84
    Offline
    Lots of different braces and kits available. Check it out several of the venders here sell different body and frame strengthening parts for front and rear. Some bolt on some need to be welded but alot is available, just do a little research and buy from whomever you like.
  3. TurboJames
    TurboJames
    Expand Collapse
    Feb 8, 2015
    100
    2
    Offline
    Which kits are the most beneficial? I will be doing some track racing and i dont want to twist the frame and or bend anything. What has everyone had succcess with and or notice a difference?
  4. Gene Van Horn
    Gene Van Horn
    Expand Collapse
    Feb 20, 2013
    618
    84
    Offline
    That depends on fast your gonna be going running. I personally put the bolt in x- bracing from kirbons behind my rear seat. Also installed the bar between the frame rails in the rear. Also did all poly body mounts on the frame and transmission and engine mnts,the diagonals up in the engine bay also. Others venders have frame boxing kits you can weld in. Some guys weld up entire frame when they have the body off, its a big list, now i have a different car with a six point cage and most of the things I mentioned. Depends on your hp and goals. To be totally honest i believe the bigest difference came from the poly mnts,really changed my ttop car. Tightened it up, was like driving a different car.
  5. chopped39
    chopped39
    Expand Collapse
    Aug 30, 2004
    3,138
    100
    Offline
    Depending on power levels you might want to install lower control arm braces as well as everything stated above. They now sell a bar that bolts in at top of rear shocks. The x brace or the Gnx bolt and or weld in one that goes behind rear seat is nice. The body bushings are a great upgrade. The kit should have the extra GNX bushings included. Kirbans.Gbodyparts and many others will have what you need. Make sure you check feedback forum on people you plan to buy from. Good luck
  6. ~JM~
    ~JM~
    Expand Collapse
    I Smell Bullshit!
    Oct 31, 2007
    1,457
    211
    Offline
  7. Johnnie
    Johnnie
    Expand Collapse
    Apr 20, 2015
    174
    52
    Offline
    My stock '87 GN has that Sc&c triangular front brace, the brace that goes between the rear upper shock mounts, stock body bushings from kirban's -- including the gnx bushings....and the TinMan behind the back seat gnx sheet metal brace bolted and epoxied in place. No more squeaks or rattles. Had good service from the vendors as well.
  8. TurboJames
    TurboJames
    Expand Collapse
    Feb 8, 2015
    100
    2
    Offline
    Thanks guys. I have all new bushings and a big fmic in front so im limited to space. I was really thinking about the seat brace, and the support braces across the rear frame rails
  9. 1KWIKSIX
    1KWIKSIX
    Expand Collapse
    Sep 29, 2007
    1,727
    88
    Offline
    Just finished installing mine. Here's a pic before it got powder coated.
  10. SpeedRacerX
    SpeedRacerX
    Expand Collapse
    Jan 20, 2014
    456
    84
    Online
    Does anyone feel this brace made a noticeable difference?
    Sent from my SAMSUNG-SM-G900A using Tapatalk
  11. 1KWIKSIX
    1KWIKSIX
    Expand Collapse
    Sep 29, 2007
    1,727
    88
    Offline
    For me it's too early to tell yet, as I haven't driven the car since it's been installed. Car still up on jack stands....Got the rear end out now being cleaned up and re-finished.
    However, with the rear frame rail brace and UMI's shock tower brace now installed, it's gotta help firm up these frames in the rear area. In addition because I have rear coil overs on my car the UMI shock tower brace will reinforce this area which is now taking the load vs the spring pocket in the rear frame area.
    I would think if you had the (2) solid aluminum rear bumper mounts installed there wouldn't be a real need for the rear rail frame brace because the inner bumper support would now be attached solidly to the bumper mounts , tying it together & preventing movement in this area. Because the shock absorber bumper mounts are able to move (telescoping inside each other at impact) there is some free play and allows for a small amount of movement and doesn't make this a rigid structure.
  12. Ken Adams
    Ken Adams
    Expand Collapse
    Dec 31, 2007
    273
    5
    Online
  13. m3x1c0
    m3x1c0
    Expand Collapse
    Bad luck Buick
    Jun 16, 2014
    504
    23
    Offline
    I have a very low-tech version of this (made from a sign post lol). I took it off for shits and giggles one day and noticed a lot more squeaky squeak in the rear. The brace that goes up above the rear shocks Would probably be just as good although I don't know if it would have as much leverage.
  14. blklt1z28
    blklt1z28
    Expand Collapse
    Jul 6, 2012
    125
    15
    Offline
    IMO.....ANYTHING that can be done to strengthen up the frame in a G body should be done. Wether it's a cruiser, a racer, road or drag, or a daily you will notice it. Even more so on a t top car.
    When I brought my Monte down to a bare frame I had it level on 4 jack stands, one at each corner. I could pick up a rear frame horn a good 6-8" before any other point came off a jack stand. After all the bracing and boxing I did to the frame I tried it again, the second the frame horn lifted off, 2 others came up with it. Mind you this was a bare frame with only a tranny crossmember bolted in. No suspending, steering etc. not even brake lines.
  15. blklt1z28
    blklt1z28
    Expand Collapse
    Jul 6, 2012
    125
    15
    Offline
    IMG_8072.PNG IMG_8069.PNG You might not be able to tell but there are also bars running down the the UCA mounts on the frame so everything is tied together. I also boxed in the open C channel of the frame.
  16. sackracing
    sackracing
    Expand Collapse
    TSM RRA
    Staff Member
    Jun 28, 2001
    2,456
    251
    Offline
    Not a kit, but not nearly as expensive as it looks.
    • Like Like x 1
  17. JAMCAR223
    JAMCAR223
    Expand Collapse
    Apr 28, 2014
    408
    119
    Online
    VERY NICE !
  18. TurboJames
    TurboJames
    Expand Collapse
    Feb 8, 2015
    100
    2
    Offline
    Very nice!!! X2 lol
  19. dank GN
    dank GN
    Expand Collapse
    always something
    Jan 11, 2009
    2,093
    159
    Offline
    Here is a lil collage of when I rebuilt my car . I boxed the frame rails . Put some diagonals in the rear . I also have the rear seat brace . The front horn brace . O and all of it was made not bought cost the price of steel and alil time .
  20. TURBOELKY
    TURBOELKY
    Expand Collapse
    Jun 27, 2005
    3,157
    244
    Offline
    Now that looks solid
Share This Page
