SpeedRacerX
- Jan 20, 2014
At a high-level, I have a TA-49 turbo running 22# on street, 25'ish at the track, Alky, Turbo Tweak Alky Chip, 42# turbo tweak injectors, Racetronix fuel injector harness, Racetronix adjustable FP regulator, turbo tweak 255LPH fuel pump, hot wire kit, 3" DP, CAS V4S SLIC, big mouth intake and stuff I'm probably forgetting related to fuel and air. Car runs 12.2@109 with 1.6x 60-foot at 22# of boost but I know she has an 11.9 in her when I can get the boost above 22# at the track. WG actuator issue that is being corrected.
Question: how far can the Turbo Tweak 255LPH fuel pump take me? Not sure if I should ask for an answer based on rwhp, quarter-mile, boost/turbo combo, etc.
If I go bigger turbo next Spring, front mount, etc.; will this fuel pump and injectors cut it? Where is their limit?
Thank you for your advice.
