johnplogii
Senior citizen
- Aug 13, 2005
I believe we have a fuel problem on a friends car. The car has an atr double pumper, new filter, 72lb injectors. With only the main pump connected the car runs pretty well but as boost goes up fuel pressure goes up then drops to about 35psi under wide open throttle 21psi boost. The thing is it still pulls strong & doesn't miss or hesitate. With the second pump hooked up the fuel pressure ramps up with boost to approx 60psi but the car spits & sputters like it should have done when the pressure dropped to 35psi. Any ideas? The one pump should be enough unless the pump is weak. Any help is appreciated.
John Plog
John Plog
