Good power by White Racing in Michigan
Fab Shop
Another satisfied customer of E-85 Fuel. White racing has tuned my car to make 620rwhp at 24psi (23.5) on very safe tune and back those #'s up run after run. Had one dyno run at 26psi and seen 642rwph at safe levels. The best part about all this it only took $52 to fill my tank.
Mods are in signature.
If your in the Michigan area and thinking of switching to e-85 I give thumbs up to White Racing in Warren, Michigan.
Did you do that with the 160's and double pumper? What size feed line?
Nice numbers!
Sorry, I put lucas 120# injectors in and yes with red's double pumper. Fuel lines are stock from tank to rails. Fuel pressurre at the rail remained constant through the entire run(s).
Thanks for the reply. Do you know what the duty cycle was on the injectors?
73% duty cycle
That's pretty good! I would have figured that the e-85 would have required a lot more fuel to make that hp.
I want to try it out on my car, but I only have 95# injectors, which I feel is too small to make anything over 600.
