Help!!!!!!!!!!!!!!! please respond
speed1
So guys what is the correct ohm readings for a perfectly working coil pack ???? Put the new one on if your are following my Saga
11k-13k across the coil pairs. This will tell you if the coil pack is good, but it will not tell you if it's bad. i.e. - A coil pack that ohms out good can still be bad, but if it ohms out bad, you can be sure the coil pack is bad. Does that make sense??
So if it doesn't Ohm out 11K-13K it's definitely bad...
Is there a way to test it to be definitely good?
I have a bit of a stumble and want to make sure before I purchase a new one.
Is there a way to test the spark module?(is that what its called?)
Thanks.
Ron
My last one ohmed out to be good when the TR was cold. After driving & it was good & hot, it started to act up, I ohmed one set at 75k ohms. I had a type II on hand & it works fine.
