LC2 ROD
The original LC2 ROD
 - Nov 4, 2002
Hello, I have an existing shop, pole building construction with metal siding and roof.
Between the metal siding and the gurts is a vapor barier/ insulation, approx R-5 sandwiched between plastic.
So here is the question, I am building 2 by 6 construction walls inside and want to add insulation.
If I put batted R-19 (fills the 6" wall) and put OSB interior wall over the insulation is the original R-5 at the metal siding going to cause a problem, moisture point?
I have been all over the internet and have info overload, so if you do this for a living please chime in.
Some things I read is to cut slices in the first inside layer of the orginal stuff before adding the new stuff. Some say it doesnt matter.
Also what side of the OSB goes to the inside, shinny coating or bare. (interior wall)
Any input from building experts would be very helpful.
Did I leave out some info?
