Help with these vacuum lines.
bishir
Serenity Now
These two vacuum lines that go under the heater box I assume are for the ac door operations correct?
One comes into a check valve into the engine compartment which also appears to connect to a vacuum source an other items like cruise.
The other just seems to go this fitting.
This fitting goes?
I believe that one goes to the heater water valve. And yes the other one goes to the check valve on the firewall behind the egr valve
