An update on my fan relays and some schooling needed. I installed the new relays and took it for a test run. I still have a problem because when I parked it and the ac had been running the fan would not shut down even after a lengthy wait. I unplugged the relay so we could leave the car. When we came back to the car I plugged the relay back together, no fan came on and we came home. This evening I went out to check it out. The car was cold, I started it and turned the ac on, let it run for a few minutes, turned it off and the fan would not stop running. I turned the engine off and then turned the ignition to on without starting and the fan was stopped. I then started it with the ac off and when I turned the engine off the fan was not running. So what would cause the fan to keep running only when the ac was on even on a cool engine?? What to check next? Thanks, Leon
